We are in a major heat wave here in Arkansas...and using true "hillbilly" ingenuity, I was able to strap the AC to the back of the bike...now I gots to figger out how turn thems vents around. :rotf:
Good idea ... now if only I can figgure out how to mount a FURNACE to ours! LOL
sounds to me ... like ..uuhhmm?? you guys should just trade bikes!!?
his is too hot....n yours is too cold?? seems like a good trade??:whistling::stickinouttounge:
Put a strap around the ac and tie to a tree branch. Git a bunch of yer buddies to help you twist the bike around so it points the same way as the vents.
Just drive with the wind to your back and the breeze will cool you. Of course you might not want to Open up too much on the gas and outrun the cool air.
Or you could order the real motorcycle A/C system, though it's still in production and not available yet.
http://entrosys.com/
http://entrosys.com/wp-content/themes/ColdStone/timthumb.php?src=wp-content/uploads/2010/01/1-large.jpg&h=250&w=883&zc=1&q=100
hope it doesnt weigh more then 10 lbs.........:biker:
PS: dont forget to run the AC drain line to your bikes overflow tank....
