silverdeer0454 Posted July 7, 2011 Posted July 7, 2011 I have a 2005 RSTD with Khromewerks exhaust, K&M air filters, and no other modifications. Over the past week or so I have had the following problem: When the bike sits overnight or cools down for several hours it starts but only runs on 3 cylinders until I rev the engine a few times then I can actually hear a change in the pitch of the exhaust and the other cylinder fires up. I have installed new plugs (rear only) yesterday and it still have the problem. I'm pretty sure it's getting gas because if I let it idle I can smell gas. I know its only running on 3 cylinders because I do the "touch test" on the headers. The cylinder affected is (as your sitting on the bike) the back right cylinder. After I rev the motor a few times the header gets hot like the others. It runs normally the rest of the time, it's only when it cools off that I have the issue. Using the choke doesn't really make a difference.
Squidley Posted July 7, 2011 Posted July 7, 2011 I would check for spark on #3 cylinder when cold, and see if it kicks in after it's warmed up. It's not uncommon for the G2's to have bad coils, I know of several that have been replaced under warranty
V7Goose Posted July 7, 2011 Posted July 7, 2011 The pilot jet on that carburetor is plugged. You can check this by simply pulling off the vacuum line from the port and spraying a little carb cleaner or starter fluid on that vacuum port right after you start the bike - if you have spark, it will immediately pick up the RPM. Goose
silverdeer0454 Posted July 7, 2011 Author Posted July 7, 2011 Thanks Squidley and Goose. BTW: Goose I found the thread on how to identify a bad coil and the spark plug caps. Going to check that as well this weekend.
