Well, I bit the bullet today and called Works Performance Products. I guess I will find out if it is worth the money or not... :confused24:
SHOCKING AIN'T IT.....:whistling:
let me know how your set up goes... still messing with mine, and it still bottoms out and is spungee, have a bit more tweeking I can do, but so far not impressed.
good luck
Jeff a few things I found out after having the shock (Work Performance Products Inc) (Works Shocks) for a few years, It been an excellent shock, it’s little hard to get the adjustment just right, and a little pricey other then that it’s all good. It’s coming up on a rebuilt soon, and $50.00 for the rebuild, that’s the part I’m liking.
You can check your shock by pushing on the back of the bike, check for bouncing, spring, spring up and down with no resistance it’s bad, the best way to do this is to fine another new venture and check the bounce on the new bike then check yours, then check the new bike over and over until you really see the different. .
It’s amazing how many drive around with a bad shock and don’t know it, I did for one and riding two up is extremely hard on the shock.
If I remember Jeff I sent you the info on the shock. If any one needs the info let me know and I’ll post it again:sun:
:7_2_104[1]:
