  smokeeater said:
I am looking for a kit to convert my turn indicators into running lights, any suggestions? I'm looking for an easy install if possilbe. thanks
Get ahold of panjandrum here on the site as he got an LED kit that adds brake & running lights to his rear signal lights. I installed them for him ... wasn't too difficult of a job but you have to disassemble the mounting hardware to run the wires.
I removed the marker lights, and then setting the depth with a drill stop, I drilled holes in the back of the marker light without hitting the iinside of the front lens.
Then I installed 12 volt led lights using black RTV to seal the lights in the drilled holes.
Worked like a charm..:biker:
In fact, I also installed brake led lights in the rear marker under the license plate.
