I lost the bolt that holds the rear brake caliper bracket to the swing arm.
Page F-3 of the service manual
Ref #4
Part # 95024-10030-00
Discription- Bolt, Flange
I'm sure I can get one at Ace if I can find the size, pitch and tpi.
Thanks!
Thanks!
Give me a couple minutes, looks like I can take that one out without taking the bag off.
I'll check it and get right back to you.
Edited by Scooter Bob
10mm dia.
1.25 mm thread pitch.
30mm under the flange length, If you can't get a flanged bolt, I would look for 32mm and fit a washer.
Happy shopping, Scooter Bob
  1 Canuck said:
You also may want to check the grade of that bolt/capscrew. Grade 5, 8, 10 or ?
Just a thought.
I don't see any grade stamp on the bolt head. Looks like it was made to be pretty.
Since braking doesn't stress the bolt, except when backing up, I would think any grade you can find would be fine.:scratchchin:
Better grade might get better corrosion protection though.:confused24:
