GolfVenture Posted July 4, 2011 #1 Posted July 4, 2011 Several months ago I added the Stebel electric 130db horns. I wired them thru a relay. I can hear and feel the relay clicking. So 1st looking for the horn fuse. Any thoughts welcome.
dingy Posted July 4, 2011 #2 Posted July 4, 2011 Today is a busy day for electrical issues. First, to possibly answer your question, the stock horns run through the signal fuse (20a). This is the 3rd fuse down in the glass fuse block on a stock MKII. You say you hear and feel the relay clicking, this would indicate you installed the horn the recommended way and did not run the horn circuit itself through the push button. Now, if the relay is clicking it would indicate the horn button circuit is working. I have no clue as how you wired this in. If it was me I would have used the stock button circuit to activate the relay, then ran a separate circuit from the battery with its own fuse through the relay contact to the horn. If this is close to what you did, then you probably going to be the only person on the planet to know were that fuse is. It could also be the ground side has an issue to. Gary
bendtdj Posted July 4, 2011 #3 Posted July 4, 2011 I had the same trouble at first when I installed the Wolo horns. Did you run a dedicated wire from the battery. Initially, I did not an dcould get nothing but the relay clicking. Changed to direct wire to the relay and loudness erupted. Dave
