Metal is going pretty easy if leg wasn't sore. I don't like the way the Ridge Cap fits on this stuff. With a good storm I don't see how it keep from leaking.
Looking at the pictures I can almost see your concern, but I really don't have a comment as to how it should be done or how it works.
  • Replies 897
  • Created
  • Last Reply
Top Posters In This Topic
My building package had foam to put under the ridge cap, where it goes across the ridges
Too Late!! Done started.
I do have the 3 rib metal. I looked at it for a while and put them on the flats. I guess I'll find out.
Your doing it right from the way it sounds ( never found the pic ) in the flats you are using the screws with the rubber washer :stickpoke: You should have some shorter screws for stitching the ribs may be one at the bottom and one or two either halfway or 1/4 th the way then 3/4 way up ridge cap will catch the last one.
I was going to try it on their car....Pink? or Purple??
You sound like the guy I hired to paint my porch for $200. He came to the door after 2 hours and said "I'm done, but it wasn't a Porch, it was a Ferrari..."
Dan you will need to get the nozzle adjustment right for you spray pattern. So try it out on anything neighbors cat,car, house anything will work.
Just keep in mid that painting doesn't cover up any imperfections, such as dips and wrinkles. Just try it on the Warden to see how well it performs.
Yeah she has a few dips and wrinkles......:Avatars_Gee_George:And she is sneaky!!
Tried to pick up limb bigger than I could handle. Big heave to force it over side of road. It broke loose all at once and I went over hill head first into big oak. Those things are hard. Leg took a thumping on the way. It was just sore and bruised. Crutches for couple days but have parked them again.
Edited by Yammer Dan
