I noticed some old threads about this problem and although one post said checking the wires under the seat fixed the problem, is there any other issues anyone has come across? although I know one day I will need to crack the fairing, I am trying to put that off if I can, otherwise I will start under the seat. ANy other advic?
Thanks
The connections under the seat sometimes cause problems but much more likely are the connectors inside the fairing. Other than those two places, the next thing would likely be a faulty audio head. A bit unusual but it has happened before. I'm betting though that the connectors inside the fairing are the culprit.
