asigetic Posted June 25, 2011 Posted June 25, 2011 I have installed all bulbs including the dash bulbs with LED's and I can say that it was worth every penny because the load on the battery has changed from 15 amps to around 2 amps with a inductive amp meter wrapped around the ground side to see the diff. Jumper the CMU for running and brake lights and installed a 50watt 6 ohm load resistor kit on the let and right side to trick the turn signal relay just enough to have it flash. Will post pictures tomorrow of what I did and if any body needs the info on what bulbs went where I can send that to you. The total cost was around $130.00 for every bulb and the two load resistor kits. Now on to the rest of the bike to finale finish her up and give it a ride..
asigetic Posted June 26, 2011 Author Posted June 26, 2011 Here is the bulbs I used and the website I bought them from if any body is interested http://www.superbrightleds.com ---------- PRODUCT INFORMATION ---------- Qty | Product / Options | Price/ea | ============================================================ 5 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-W4-90: Cool White Wide ------------------------------------------------------------ 1 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 1.59 | WLED-R4-32: Red Narrow ------------------------------------------------------------ 2 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-G4-32: Green Narrow ------------------------------------------------------------ 1 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-B4-90: Blue Wide ------------------------------------------------------------ 3 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 1.59 | WLED-A4-32: Amber Narrow ------------------------------------------------------------ 2 | 1156-x30: 30-LED BA15S bulb| $ 8.99 | 1156-A19-WV: 1156 Amber 100 Degree ------------------------------------------------------------ 2 | 1157-x3X1W: 3 x 1.3 Watt High Power LED BAY15D Bulb| $ 16.95 | 1157-A3X1W: Amber ------------------------------------------------------------ 2 | 1157-R19W6: Motorcycle Tail 19-LED 1157 Bulb| $ 12.99 | ------------------------------------------------------------ 2 | RL-650: Tail Light Load Resistor kit | $ 4.95 | ------------------------------------------------------------
