Ok, I must just be stupid. I have tried searching for the TSB or letter that has been discussed here. (so I can show it to my dealer that says no to the replacement of the clutch basket.0
I want to take them a copy so I can get the I basket change before warranty runs out.
Can anyone that knows where it is send it to me or provide a link.
Thank you greatly in advance.
Signed
"Search Challenged and bug-eyed"
:confused24::confused24::confused24:
If no one can point you to it, call Yamaha's 800 # and ask them about the directive. Or you could start at the Regional Rep and work your way up... provided you have time left on your warranty.
Do a search for "Service Bulletin" and you'll see similar threads. If I come across the TSB I'll post it.
Thank you. I have been searchin using that and several alternate words and still cant find it. I see losts of comments to do a search for it but no luck in finding the actual TSB
I had a really boring day at work today. When I did the search for "service bulletin" I went thru the hits and found the reference. It is there.
Since other's might need this info easily accessible... is there a way to put it as a sticky? Maybe in the technical documents area?
We should have a Tech Bulletin section, read only of course. Didn't you say you were bored Don and wanted something more to do, I am sure I heard you say that.
:big-grin-emoticon:
