Guest Wilson
Has anyone had trouble with the little switch on the Yamaha Passing Lamps for an '05 RSTD.
If so, what, and how, was the problem resolved. :confused24:
Thanks in advance.
:bobby:
If your refering to the push button switch that comes with the lamps,I replaced mine with a toggle switch that I picked up at radio shack for under ten bucks and you can probably get one at any auto parts store, autozone, pep boys,etc.
I replaced mine with one that came with the JCWhitney handlebar switches. It came apart before I finished installing the lights. I took the switch out of the circuit and used the shell to fill the hole in the lamp.
I would suggest you bypass the switch and just let the lamps come on with the bike until you find a replacement.
Good luck.
