Has anyone ever had to change the y pipe on their 02 venture? If so where did you buy it. Also should I change the other side at the same time
I'd think it all depends on why you need to replace the header?? If it's rust due to your climate, humidity, and salt water inviornment, I'd replace both... just because. If you crunched it, and the other side looks OK then replace the one side. Never have had to replace the header but being on the outside it shouldn't be all that much of a hassle...
