hillrider Posted June 19, 2011 #1 Posted June 19, 2011 While pulling & greasing the steering head bearings, I found a small (3/16) hole leading to the upper frame member. Can anyone think of a good reason not to plug this hole. The thought is to put a zerk fitting on the side of the head and be done with pulling this bugger apart to grease the bearings. I think the hole is there to releave pressure while assembling the frame. Since the frame is complete - plug the hole.
royalstar09 Posted June 19, 2011 #2 Posted June 19, 2011 hillrider said: While pulling & greasing the steering head bearings, I found a small (3/16) hole leading to the upper frame member. Can anyone think of a good reason not to plug this hole. The thought is to put a zerk fitting on the side of the head and be done with pulling this bugger apart to grease the bearings. I think the hole is there to releave pressure while assembling the frame. Since the frame is complete - plug the hole. http://www.venturerider.org/forum/showthread.php?t=45540&highlight=hole+steering
hillrider Posted June 19, 2011 Author #3 Posted June 19, 2011 Thanks Royalstar. I hate being old. That being said, everyday has something new.
royalstar09 Posted June 20, 2011 #4 Posted June 20, 2011 hillrider said: Thanks Royalstar. I hate being old. That being said, everyday has something new. Not a problem. I tend to read a lot and I rembered something about that hole. Just went to second Generation section and searched for "steering hole" and it showed up
