Type your post and before you submit it, scroll down and you'll see "manage attachments". Click on that, select and upload the picture and then submit your post.
heres some pics. i bought it with the fuse block like this. looking at the upgrade, mines a mess! as you can see, running lights work....no taillights. i guess this will be a good thread for the "not so inclined" user. ill make sure to do a detailed installation of the new fuse block, when it comes, and anything else with the cpu. ive also changed the plugs, custom wires, aluminum reusable niche fuel filter, new water pump (ouch!..2 attempts to rebuild it were unsucessful), new seat cover and backrest, new brake pads (dp), cupholder, mp3 attachment, h.i.d., now led's. lots and lots of elbow grease. have a HUGE wish list of other items. its just a really cool bike. i love it!
Edited by reddevilmedic
well, i found the tcu, under the batt box. how in the world do i get it out?!:shock3: update: instead of removing it at this point (waiting till i get fuse box), i cleaned the contacts with 600 grit and contact cleaner. reassembling now.
:shock3: i believe im running on two cylinders. the carb diapragms just fell apart in pieces when i opened it. no holes in diapragm! do i epoxy the metal cap and black cylinder back together? i tried just cleaning and reassembling, but it just blows apart again. if so, is the small hole in the black cylinder supposed to go a certain direction? dont want to epoxy it together wrong. thanks.
If your carbs are as bad as you indicate, this might be an option.
I just ran across this on ebay, Item # 330576075357
Repairing the sliders is not something I would consider. If one comes apart while it is running and gets into block, it will be fugly.
Gary
well i did the epoxy repair. so far, all the sliders seem to be operating correctly. bike idles smoother, as has quit coughing. should be a temp fix till i can get the replacements. thanks for everyones help. next, fuse upgrade and led's.
