barend Posted June 12, 2011 #1 Posted June 12, 2011 Went out riding yesterday and on the way home ran slap into a major downpour:depressed: (***note to self: stop and don rain gear :doh:before you hit wall of water:rain2:) Anyway, stuff in the trunk and bags got wet, I know there is a "gasket" running through the lid, can these still be had and if so where? If not, what are the alternatives? Thanks
Midicat Posted June 12, 2011 #2 Posted June 12, 2011 I did a parts check on Yamaha Parts List. Part #54K-2847F-00-00 shows as "seal" and is listed "obsolete" by Yamaha. From the diagram, I can't tell if it's a rubber seal or the metal seal we have on the lid and base. Either way, you can't get it from Yamaha. Thomas
Condor Posted June 12, 2011 #3 Posted June 12, 2011 You might try using that rubber bead they sell for installing screens in doors. Comes in a couple of sizes.
Snaggletooth Posted June 12, 2011 #4 Posted June 12, 2011 Yep, that works! Takes a while to do but it does seal up nice and tight.
barend Posted June 12, 2011 Author #5 Posted June 12, 2011 Did you use the .125 or the .140? If I measured correctly the gap is an eight but .015 more might be a better seal? Yep, that works! Takes a while to do but it does seal up nice and tight.
Snaggletooth Posted June 12, 2011 #6 Posted June 12, 2011 LOL! I have no idea. It's been about three years since I did mine. I started picking at the trunk looking at the seal and thought about what could be used to replace it. I had a bunch of scraps of the beading from doing several screens and started trying them. They fit with a lil encouragement. Worked out ok. Sealed well. I lined my trunk a couple of seasons back and it stays dry. And I ride in the rain a LOT! So all I can say is it was grey and ribbed. Mike
