vintagewindmc Posted June 6, 2011 Posted June 6, 2011 going to romove handle bars on a 83 for polishing looks like one nut holding grips on, I assume 1 or 2 bolts at base under black plastic riser cover? can they be removed from grips an base with out disconnecting any wires ? Any help greatly appreciated Tom
Condor Posted June 6, 2011 Posted June 6, 2011 going to romove handle bars on a 83 for polishing looks like one nut holding grips on, I assume 1 or 2 bolts at base under black plastic riser cover? can they be removed from grips an base with out disconnecting any wires ? Any help greatly appreciated Tom This should help a bit... http://www.venturerider.org/forum/showthread.php?t=505
vintagewindmc Posted June 7, 2011 Author Posted June 7, 2011 This should help a bit... http://www.venturerider.org/forum/showthread.php?t=505 Thanks Man Tom:fingers-crossed-emo
