http://i257.photobucket.com/albums/hh221/muaymendez/IMAG0235.jpg
Will the angle of the bars cause problems with the feed of fluid for the brake and the clutch??
http://i257.photobucket.com/albums/hh221/muaymendez/IMAG0236.jpg
I don't see any reason that it would.
Your outlet is still way below the fluid line and the system is pressurized so as long as you are not vertical with the outlet at the top there should not be any issues that I can foresee.
My angle is just as low as yours (maybe lower) and have no issues at all. Except checking fluid levels with caps off!! :shock3: thankfully i had rags on the tank!!
:clap2::clap2: YES MAN !!!! that is too funny. Thanks for the responses. I will be getting some risers and then will be able to move the bars a bit.
These are road glide bars and they feel better but A lil too forward.
