Kregerdoodle Posted December 2, 2007 #1 Posted December 2, 2007 I rode around 200 miles yesterday, and picked up a light vibration.... it is coming up the bars and just enough to make your hands tingle... any Idea on what to check out ????
BOO Posted December 2, 2007 #2 Posted December 2, 2007 My first thought is air pressure but you said slight, hmmm I would still start with the air pressure and then ck and see if you threw a wheel weight. Wheel bearing? Probably not but you can get the front tire off the ground and spin the wheel, you should be able to feel the bearing if it is rough or maybe even hear it. Good Luck, Jerry
Kregerdoodle Posted December 2, 2007 Author #4 Posted December 2, 2007 Thanks, I`ll check the wheel out, I have been instructed that I MUST put the xmas lights on the house before anything else....
