Does anyone know if they are doing any construction on 694 around the twin cities? I plan on leaving from Helena, MT on the 20th of June and passing thru on the 21st???
Thanks,
Rabbit
Looking at the construction site and just driving thru that area, you will have no problems as they dont start construction till August. But be prepared as that area is a congested area on a good day. Just make sure you are in the fast lane, ie left lane when you cross I35W as the right lane becomes an exit only lane once you each Snelling, about a mile east of I35W.
Good luck and dont hit the afternoon rush, which is about 2pm till 7 up there..
Where you headed to?
Rick F.
Looks like they have some construction on 694 here is their web site, 694 is very near the bottom if the page Good luck if it works out I'll buy you a cup of coffee when you go through fargo let me know
John
Current Construction Projects - Minnesota Department of Transportation
Grump & I are at the Fargo motel 6 behind the Flying J, we just got in about 03:30.
Guess checkout is about 10:00 & we continue on to Whoomp's stomping grounds.
