bluemagic Posted May 30, 2011 Share #1 Posted May 30, 2011 can anyone tell me the name of the brake line conection value near the steering head. and where i may be able to fine one. it has a small rubber boot on it the size of a nickel. mine has a small leak. it only leaks if i push it w/my thumb any help would be greatly appreciated thak you. 89 vr. Link to comment Share on other sites More sharing options...
CrazyHorse Posted May 30, 2011 Share #2 Posted May 30, 2011 can anyone tell me the name of the brake line conection value near the steering head. and where i may be able to fine one. it has a small rubber boot on it the size of a nickel. mine has a small leak. it only leaks if i push it w/my thumb any help would be greatly appreciated thak you. 89 vr. Believe its called metering valve. Link to comment Share on other sites More sharing options...
friesman Posted May 30, 2011 Share #3 Posted May 30, 2011 I dont know what its called, but you should be able to look it up here using the parts diagrams and order it too, their prices are usually pretty good. http://www.partshark.com/custompage.asp?pg=yamahaparts Brian Link to comment Share on other sites More sharing options...
dingy Posted May 30, 2011 Share #4 Posted May 30, 2011 I dont know what its called, but you should be able to look it up here using the parts diagrams and order it too, their prices are usually pretty good. http://www.partshark.com/custompage.asp?pg=yamahaparts Brian It's shown on the front master cylinder 1 page. But does not appear to be available. Gary Link to comment Share on other sites More sharing options...
dingy Posted May 30, 2011 Share #5 Posted May 30, 2011 can anyone tell me the name of the brake line conection value near the steering head. and where i may be able to fine one. it has a small rubber boot on it the size of a nickel. mine has a small leak. it only leaks if i push it w/my thumb any help would be greatly appreciated thak you. 89 vr. I looked at the one I removed from my bike. If there is fluid under the rubber cap, it needs replaced. I don't know of a rebuild kit for these. Might check with MiCarl or Skydoc17. One of them will know if it can be rebuilt. Gary Link to comment Share on other sites More sharing options...
bongobobny Posted May 31, 2011 Share #6 Posted May 31, 2011 Yes, it is a metering valve. Not much in there other than a precision size oriface to regulate flow rate of the brake fluid to the front brake. Not to be confused with the proportioning valve at the rear cylinder which is a time delay from when you apply the rear brake until fluid starts to flow to the front brake... Link to comment Share on other sites More sharing options...
bluemagic Posted June 1, 2011 Author Share #7 Posted June 1, 2011 thank you for the help Link to comment Share on other sites More sharing options...
