What type and brand of oil is everyone using in their final drive? Can you use a multi viscosity oil? I had a difficult time finding SAE 80 GL-4.
I run the SuperTech 80W140 regular oil now.
Yep, I saw that 80W140 at Walmart as well as the 75W90 SuperTech. Athough Yamaha does not list 80W140, I am tempted to use it on my next gear oil change sometime this weekend. How long have you used the 80_140 on your bike so far?
I double checked my gear oil weight that is in the garage and it is 80W90 weight. The 75W145 looks to be a little heavier, but I am inclined to give it a try.
Ive had it in there for about 10,000 miles give or take. I usually change the final drive oil every or every other engine oil change depending on my mood. 1qt of gear oil will do 8 oil changes in the final drive.
