muaymendez1 Posted May 23, 2011 Posted May 23, 2011 This is a different bike than on my signature. The bike in question is the 99 rs venture.I usually dont forget steps when reinstalling parts but I know I did this time. The crossover vent lines one on each side of the carb sets, left and right. Where are those tubes comming from? If I would have seen them i would not have forgotten to remember to put them where they belong:fiddle:. Where should I look for these and am i right tinking that these are just vent tube or are they vacuum? While we are at it , does anyone know a post on making a bracket for the stebel horn?
54chevybelair Posted May 23, 2011 Posted May 23, 2011 carbon one has a stebel bracket for sale in the classifieds
V7Goose Posted May 23, 2011 Posted May 23, 2011 You have not described the "vent" lines well enough to be sure of answering your question. The bike has two small vacuum hoses that connect to the brass nipples on the intake boots just below the carbs (the other two nipples need rubber caps). ABOVE the carbs, but under the big intake plenums, are two overflow vent tubes that connect to a rubber T connector between the carbs on the outside edge near the diaphragm caps. Goose
muaymendez1 Posted May 23, 2011 Author Posted May 23, 2011 The 2 overflow tubes are what i forgot to install. Where should the tubes go to. Maybe I should trace them back and take them to the carbs. thanks for the help
