kevstar1300 Posted May 19, 2011 #1 Posted May 19, 2011 I looked at older posts trying to find someone who knew where I can find clamps for RK slip-ons for '07 RSTD. Anyone who has any please contact me...318-268-4882 or kevinandmona@hotmail.com THANKS
Guest scarylarry Posted May 19, 2011 #2 Posted May 19, 2011 Are you talking about the chrome clamps for the pipe or the mounting brackets under the saddle bags?
kevstar1300 Posted May 19, 2011 Author #4 Posted May 19, 2011 I see where I posted for "clamps, meant to type brackets, sorry.
Steel Horse Cowboy Posted May 19, 2011 #5 Posted May 19, 2011 Kevin, do you have the tools and metal to make a set if you had an outline to go by? If so, I can fax you an outline that I have. I'm not computer savy enough to send it to you through the computer. Most use steel flat stock, but I make mine out of 3/16 aluminum. C.R.
Hummingbird Posted May 19, 2011 #6 Posted May 19, 2011 you can also go to lowes/menards/home depot and get a pair of emt straps ($1.29 ea.) and 2 short bolts and use them for a mount. If you get the clamp with the 'rubber' insert you'll have to get a larger size than the diameter of the pipe on your bike. I wish I could remember the sizes but I do remember the bolts have to be 1/2" or 3/4" long and use a flat and lock washer. I only did one RSTD and that was a couple years ago -
Ponch Posted May 19, 2011 #7 Posted May 19, 2011 Check with WilsonTAMU (Kelly). I think he has a set of brackets.
new guy Posted May 19, 2011 #8 Posted May 19, 2011 Go to lowes-depot and by 2 and put them on the rail under your saddle bags. Take your pipes with you so you can get the right size bolts if you didn't get them with the pipes. The only thing I know for sure is to get the 1/2 in ones 3/4 is too long. Hah you laugh but they work.http://shop1.mailordercentral.com/marshfasteners/images/RLTHUMB.JPG Pat
Hummingbird Posted May 22, 2011 #9 Posted May 22, 2011 Go to lowes-depot and by 2 and put them on the rail under your saddle bags. Take your pipes with you so you can get the right size bolts if you didn't get them with the pipes. The only thing I know for sure is to get the 1/2 in ones 3/4 is too long. Hah you laugh but they work.http://shop1.mailordercentral.com/marshfasteners/images/RLTHUMB.JPG Pat That's what I was talking about
M61A1MECH Posted May 26, 2011 #10 Posted May 26, 2011 Kevin The brackets are available from KromeWerks, the mufflers thay sell fo rthe Venture / Tour Deluxe were made for the Harely Road King, so they should be a direct fit. See below for the email I received from Kromewerks. You will need 1 each 680855 Bracket , left 1 each 680856 Bracket , right 2 each 2099801 nut plate 680855 $10.00 680856 $10.00 2099801 $3.00 Prices are less shipping (UPS ground is standard.) We accept Visa, MasterCard or Discover. To order, call Monday through Thursday 9-6 central. Customer Service Khrome Werks div. D.S. Manufacturing, Inc. Ph. 952-758-9523 Monday through Thursday, 9-6 central www.khromewerks.com
MidlifeVenture Posted May 26, 2011 #11 Posted May 26, 2011 http://www.venturerider.org/forum/showthread.php?t=34426 the tapered ones are easy to make cutting wheel and dril
