dingy Posted April 23, 2012 #26 Posted April 23, 2012 KIC said: Anybody have a picture of the "banjo" bolt is and where it is located ? I haven't been able to successfully bleed the rear and front of my 87. When I get back in town, that will be my #1 goal on the 87. Next to installing new carb diaphragms. All of the bolts that mount a brake line to a caliper or master or splitter are called a banjo bolt. They have a hole down the center line and then a cross hole where the brake line attaches. If there are 2 brake lines on one point, there will be 2 cross drilled holes. Gary
KIC Posted April 24, 2012 #27 Posted April 24, 2012 dingy said: All of the bolts that mount a brake line to a caliper or master or splitter are called a banjo bolt. They have a hole down the center line and then a cross hole where the brake line attaches. If there are 2 brake lines on one point, there will be 2 cross drilled holes. Gary Ahhh...thank you.
