If anyone has one that is in good condition, I'd be interested in it. Mine doesn't stay in the position you put it in. It has worn itself out, I guess.
Phil
I drilled a fine hole in the pivot mechanism under the rubber boot and inserted a small screw with a bent washer to tighten things up a bit. loosen the screw to adjust mirror and then tighten
Brian
Thanks guys, I'll give the small screw and washer trick a try first. Once I have it where I want it, it doesn't need to move.
Cheers.
  • 2 weeks later...
