509jim Posted May 10, 2011 Posted May 10, 2011 Hi all Had the bike out yesterday (85 Venture) and having problem with the radio, FM is not working AM is OK Checked most of the postings and can’t find any info on this problem I don’t want to replace the radio but would like to try to fix it. Thanks
paysaw Posted May 10, 2011 Posted May 10, 2011 Hi. I had the similar problem with my 83.When I first got it there was no AM.It would not switch over.What I did was I took apart the radio control and replaced the mini switch on the circuit board that controls AM/FM.I grabbed the parts from an old tape deck I had.I am not sure if that is the problem you have. Keep us posted.
bongobobny Posted May 10, 2011 Posted May 10, 2011 Now, if the band IS switching when you push the push button, tryb reseating the DIN connector on the tuner/amp module from the tuner chassis, and reseat your antenna connector. AM is easier to pick up than FM... Worse case senerio I have a couple of tested tuner/amp modules I'm trying to get rid of!
Herb In Texas Posted May 10, 2011 Posted May 10, 2011 I had the same sort of problem on a Ford pickup. turned out to be the chassis ground.
