pegscraper Posted May 5, 2011 #1 Posted May 5, 2011 The VMX rear gear unit is almost a direct swap on a 2nd gen. It only needs the blank boss milled out for the speedometer sensor. Here I am doing one for Condor. 1) Locate and bore out the main hole. 2) Machine the boss off flat. 3) Locate and drill the mounting bolt hole. 4) Tap in the threads. 5) Chamfer the holes, pull the shock bolt, take it apart and flush the shavings out real well, reassemble and it's ready to mount.
pegscraper Posted May 5, 2011 Author #2 Posted May 5, 2011 Here's a view of the gearbox not very often seen.
1joeranger Posted May 5, 2011 #3 Posted May 5, 2011 I am sure there are good reasons to swap out to a VMX (what is that?) gear box but I don't know what they are! Please enlighten me! Nice job by the way!!!! Thanks!!
pegscraper Posted May 5, 2011 Author #4 Posted May 5, 2011 The VMX rear gear has a slightly lower ratio, 33/9 where the stock one is 33/10. Better performance and acceleration. The 2nd gens are geared too high and this helps out quite a bit.
Hulign Posted May 5, 2011 #5 Posted May 5, 2011 Would you be interested in doing another one? I am really not a fan of the overdrive 5th with the stock rear gear. Thanks Frank
pegscraper Posted May 5, 2011 Author #6 Posted May 5, 2011 Sure, I'd do another one. Why not. Just make sure the VMX unit you get has the blank boss on it. Later ones have it and earlier ones don't. If it's not there, there's nothing to machine. Shoot me a pm for my address.
Squidley Posted May 6, 2011 #7 Posted May 6, 2011 Lynn, I would be interested in having the FJR rearend that I have done also. I'll shoot you a PM and we can figure it out.
pegscraper Posted May 6, 2011 Author #8 Posted May 6, 2011 Look at that closely. There are some differences in the FJR rear housing. First, the four mounting bolts are longer and require a spacer of some sort to take up the gap. That can be accommodated, but... Second, there are some machining differences on the inside where the thing goes against the wheel. I don't know if a shim or something can be changed in there or not. I don't know if FJR gear housings can be made to work.
ragtop69gs Posted May 6, 2011 #9 Posted May 6, 2011 Why couldn't you just swap out the ring & pinion, rather than milling the housing?
pegscraper Posted May 6, 2011 Author #10 Posted May 6, 2011 That requires some expensive tools I don't have, and knowledge I don't have on setting up the gear lash, plus an assortment of shims to do it. This is a world simpler to me.
rlyons Posted May 6, 2011 #11 Posted May 6, 2011 Been there, done that with the gear swap. Didn't like it at all, too low gearing so I went back to original and have had no problems with it at all,gearing is fine,plenty of power and torque. Won't say you won't like it, but for my personal opinion, the originals work just fine.
1joeranger Posted May 6, 2011 #12 Posted May 6, 2011 VMX is that a motorcycle or is it a brand name? I googled VMX and found VMX Magazine and VMX racing. Little help here please! I have been wondering what to do next. Gone to the dark side and have tinkered with the bike as much as I can so this looks like a great next step! Can't wait to here other opinions and learn more! Thanks!!!
Stache Posted May 6, 2011 #14 Posted May 6, 2011 Wizard765 said: VMX is short for V-Max. Yamaha's muscle bike.. So we're using a three letter abbreviation for a 5 character name? Yay for efficiency! I used to say my dream job in the Canadian military would be the TLA SME at the OAG. I wanted to be the -Three Letter Acronym- -Subject Matter Expert- at the -Office of Acronym Generation-.
Condor Posted May 6, 2011 #15 Posted May 6, 2011 sbarnes8478 said: So we're using a three letter abbreviation for a 5 character name? Yay for efficiency! I used to say my dream job in the Canadian military would be the TLA SME at the OAG. I wanted to be the -Three Letter Acronym- -Subject Matter Expert- at the -Office of Acronym Generation-.
pegscraper Posted May 6, 2011 Author #16 Posted May 6, 2011 rlyons said: Been there, done that with the gear swap. Didn't like it at all, too low gearing so I went back to original and have had no problems with it at all,gearing is fine,plenty of power and torque. Won't say you won't like it, but for my personal opinion, the originals work just fine. Yeah, I went back to the stock rear gear ratio also - after I put a VMX transmission in my bike. This thread is about the machining of a VMX rear gear housing. Put your opinions on the appropriateness of the gear ratios of this bike somewhere else.
Lone Eagle Posted May 6, 2011 #17 Posted May 6, 2011 pegscraper said: Here I am doing one for Condor. Who???? Condor has a second gen? Condor moves the bike off his driveway? Pegscraper, you better send him some new tires along with this mod - the old ones may have a flat spot on them - not good for a ride to Cody!!
1joeranger Posted May 6, 2011 #18 Posted May 6, 2011 sbarnes8478 said: So we're using a three letter abbreviation for a 5 character name? Yay for efficiency! I used to say my dream job in the Canadian military would be the TLA SME at the OAG. I wanted to be the -Three Letter Acronym- -Subject Matter Expert- at the -Office of Acronym Generation-. That got me laughing! Or TGML! Thanks! Or T
Grisolm1 Posted July 30, 2011 #19 Posted July 30, 2011 I have an FJR rear end coming in the mail. Do you know for sure it won't fit the RSV other than the long bolts you mention which can be possibly changed. Thanks Wally
Beau-Kat Posted August 4, 2014 #20 Posted August 4, 2014 pegscraper said: The VMX rear gear unit is almost a direct swap on a 2nd gen. It only needs the blank boss milled out for the speedometer sensor. Here I am doing one for Condor. 1) Locate and bore out the main hole. 2) Machine the boss off flat. 3) Locate and drill the mounting bolt hole. 4) Tap in the threads. 5) Chamfer the holes, pull the shock bolt, take it apart and flush the shavings out real well, reassemble and it's ready to mount. I know this is an old thread, but I have a relevant question. Was wondering why the VMax boss had to be machined flat? I put an RSV diff in my VMax (drilled and tapped for the shock mount and blanked the speedo hole). I pulled out the old VMax diff to compare the boss height on each. Both diff boss (shoulder) heights look the same to me. Looking at the boss on both diffs, I can really see no need to machine the boss flat on the VMax diff when drilling out the speedo hole and tapping the mounting screw for mounting on my RSV. Am I missing something:confused24:? Rusty
MikeWa Posted August 4, 2014 #21 Posted August 4, 2014 Why do all this work? You can get a v-max setup ready to install from RM Sportmax. $300 exchange. See the article in the tech section. http://www.venturerider.org/forum/showthread.php?t=13266 Mike
ACE50 Posted August 4, 2014 #22 Posted August 4, 2014 MikeWa said: Why do all this work? You can get a v-max setup ready to install from RM Sportmax. $300 exchange. Mike Cause I saved $150 bucks doing it myself! AND gained the experience of doing it! I'm not a 'buy it and just bolt it on' kinda guy!
djh3 Posted August 4, 2014 #23 Posted August 4, 2014 Sorry but I have not kept up with all the different V-max diff threads around. If I understand correctly the V-max will "bolt in" with some modifications mostly done by a third party shop. What they do I have no idea. but if it fits in, why can't a fellow simply put the ring and pinon from the Vmax into the RSV case?
ACE50 Posted August 4, 2014 #24 Posted August 4, 2014 djh3 said: Sorry but I have not kept up with all the different V-max diff threads around. If I understand correctly the V-max will "bolt in" with some modifications mostly done by a third party shop. What they do I have no idea. but if it fits in, why can't a fellow simply put the ring and pinon from the Vmax into the RSV case? It has to be fit, (shimmed in properly) It was easier for me to mill the speedo hole.
MikeWa Posted August 4, 2014 #25 Posted August 4, 2014 ACE50 said: Cause I saved $150 bucks doing it myself! AND gained the experience of doing it! I'm not a 'buy it and just bolt it on' kinda guy! Point taken.
