GolfVenture Posted May 4, 2011 #1 Posted May 4, 2011 The Chrome End Nut on my heal toe shifter keeps loosening. Looking for the right fix. I've attached two pictures. 1st of the Heal Toe shifter and shaft, 2nd the Chrome End Nut. I had this appart this last winter and can't seem to find all the right pieces. My thought would be to get a thin metric nut with nylon locking threads to keep the nut from loosening against the Heal Toe shifter. Then lastly put the chrome end nut on. Open to suggestions.
GolfVenture Posted May 4, 2011 Author #5 Posted May 4, 2011 oops fat fingered. The 2nd picture of the end nut won't upload. It is an end nut in the shape of a bullet, chromed.
Marcarl Posted May 4, 2011 #6 Posted May 4, 2011 yep,,, just weld it on, problem solved. Actually a little Locktite does wonders,,,, make sure it completely clean of grease and dirt.
bongobobny Posted May 4, 2011 #7 Posted May 4, 2011 Yes, they do make locking metric finish nuts but a little hard to find. Use a SS metric nut, a plastic washer, and loctite...
