2WHEELSFORME Posted November 27, 2007 Posted November 27, 2007 Didn't like the big whip antennas and I never use the CB so now I got a single short black one. Removed the CB mount and tied it up under the trunk. Got a short black rubber universial from parts store for about 5 bucks. I had to make the threaded adapter by drilling and tapping a bolt but it works great cost little and it is what I was looking for. http://bigbikeriders.com/photopost/data/500/2508antenna_cropped_red_2_.JPG
Guest tx2sturgis Posted November 27, 2007 Posted November 27, 2007 I like that ! Cool! You got a part number or something? And also, tell me about that LED lightbar...is that one of the JC whitney 14 inch bars?
Bubbajbi Posted November 28, 2007 Posted November 28, 2007 That is EXACTLY what I have been wanting to do. I also would like step by step instructions and a part # if possible.
2WHEELSFORME Posted November 28, 2007 Author Posted November 28, 2007 No part number but it is a universal antenna that can be found at several Automotive Parts places like Pep Boys ($10) or Advance ($5) and cost less than 10 bucks. It comes with a choice of several double threated nipples to use, one for ford, mopar, or imported etc. The smallest was threaded 10/32 so I used it. I have box of metric bolts and junk from takeoffs so I found one that fit the female theaded hole on the antenna mount and it is a common size bolt but is metric. Put the bolt head in a vice and drilled the center out and tapped it 10/32 to make an adapter or reducing bushing so to speak. Cut it off the desired length using only the threaded part and screwed it all together. I also had a rubber grommet laying around I used to make a smooth transistion between parts but it wasn't really needed. The other side the mount was just unbolted and tywraped under the trunk out of sight. Wireing/cables were left attached. Both sides can be returned to stock with ease. The under trunk light is a SOMA and has both run and stop functions and sells for I believe 50 bucks at J&P and other places. It says for Goldwings but comes with a mount for Ventures also. No drilling required.
Guest dakotasport Posted November 28, 2007 Posted November 28, 2007 Didn't like the big whip antennas and I never use the CB so now I got a single short black one. Removed the CB mount and tied it up under the trunk. Got a short black rubber universial from parts store for about 5 bucks. I had to make the threaded adapter by drilling and tapping a bolt but it works great cost little and it is what I was looking for. http://bigbikeriders.com/photopost/data/500/2508antenna_cropped_red_2_.JPGHey looks nice and i have one for ya all to, i got a short black steel and jus put it under the fearing and works awesome.......
Guest leemcd Posted November 28, 2007 Posted November 28, 2007 You can also use an active antenna available at Pep Boys for $20. It is a flexible that I taped on the inside of the saddlebag cover. I ran it through a spare automotive 12 v relay I had hanging around along with the Pyle Marine radio/CD I installed in the right saddlebag of my '05 RSTD. The relay is controlled by tapping off a headlight or tailight wire because these come on with the ignition.
RoadKill Posted November 28, 2007 Posted November 28, 2007 Didn't like the big whip antennas and I never use the CB so now I got a single short black one. Removed the CB mount and tied it up under the trunk. Got a short black rubber universial from parts store for about 5 bucks. I had to make the threaded adapter by drilling and tapping a bolt but it works great cost little and it is what I was looking for. Converted mine to the short fiberglass ones too, exept I did the CB too. Use it on group rides. Check out the picks in my gallery. I really like how it ended up. J
GunnyButch Posted November 28, 2007 Posted November 28, 2007 I took the antena off mine and removed the CB mount. I left the plug to the CB accessable so I could reinstall the mount and plug it back in if need for something like a large group ride or something like that. The FM mount I removed completely and repaced the antenna with this hidden antenna in the fairing. Now there isn't any visible antennas. http://www.ecshylites.citymax.com/catalog/item/604191/368050.htm The hidden antenna works well with FM but AM reception is not so good but I don't use AM anyway.
