Evan Posted April 29, 2011 #1 Posted April 29, 2011 On my way to Marcarl's this spring, I ran over something that did a job on my exhaust collector (on the highway at 70mph). Ended up with two fairly large holes on the botom, one with a large dent. Carl tried a patch but that did not hold. I tried more patching with some muffler cement and again, the heat and pressure blew holes in the patch areas. Any reason why I can't weld a patch in place? How important is it to try to straighten out the indent before patching? All comments appreciated!
twigg Posted April 29, 2011 #2 Posted April 29, 2011 Should be possible to cut out the dented bit and check for other damage ... blockage ... And weld a stainless steel patch over the whole underside.
friesman Posted April 29, 2011 #3 Posted April 29, 2011 I was pretty sure I saw a thread here somewhere when a member had a baffle come loose inside the collector and cut an openeing to remove the rattle and then just took it to a welder and closed it up with a patch like you describe. brian
twigg Posted April 29, 2011 #4 Posted April 29, 2011 Freebird wrote a great post ... I think it's in the Gen 1 Teck section
Keemez Posted April 29, 2011 #5 Posted April 29, 2011 I was pretty sure I saw a thread here somewhere when a member had a baffle come loose inside the collector and cut an openeing to remove the rattle and then just took it to a welder and closed it up with a patch like you describe. That would be this here thread: http://www.venturerider.org/forum/showthread.php?t=1002
bongobobny Posted April 30, 2011 #6 Posted April 30, 2011 Welding your collector should be OK as that's what people do when they cut into them to fix the rattle inside...
Pam Posted April 30, 2011 #7 Posted April 30, 2011 Mine is cut and gutted. Then closed up with brazing. But a mig should do as well:confused24: frank
Evan Posted May 4, 2011 Author #8 Posted May 4, 2011 Thanks all for the responses. Major help as usual! I forgot to ask one other question. I have rode quite a bit since the collector was badly punctured. Is there any reason other than leaky exhaust and noise why I should get this repair done as soon as possible rather than letting it go for a while. I do a 500 mile run fairly often.
twigg Posted May 4, 2011 #9 Posted May 4, 2011 Thanks all for the responses. Major help as usual! I forgot to ask one other question. I have rode quite a bit since the collector was badly punctured. Is there any reason other than leaky exhaust and noise why I should get this repair done as soon as possible rather than letting it go for a while. I do a 500 mile run fairly often. Holes in the collector will lead to a reduction in back-pressure from the exhaust. That will cause the engine to run lean, and much hotter than it should. You may get spitting back through the carbs and/or backfiring in the exhaust. Either way, it needs to be fixed
Freebird Posted May 4, 2011 #10 Posted May 4, 2011 Twigg is correct in the grand scheme of things but the fact is, if it is just a small puncture, it will have a very negligible effect if any. It won't reduce back pressure nearly as much as most of the after market mufflers that people install. If it's just a small puncture and the sound doesn't drive you crazy, it wouldn't bother me to ride it many miles.
twigg Posted May 4, 2011 #11 Posted May 4, 2011 Twigg is correct in the grand scheme of things but the fact is, if it is just a small puncture, it will have a very negligible effect if any. It won't reduce back pressure nearly as much as most of the after market mufflers that people install. If it's just a small puncture and the sound doesn't drive you crazy, it wouldn't bother me to ride it many miles. That, of course is true too
Squidley Posted May 4, 2011 #12 Posted May 4, 2011 That, of course is true too Oh Dont tell him that...it only swells his ego!
bongobobny Posted May 4, 2011 #13 Posted May 4, 2011 One of the downsides of having an exhaust with minimal back pressure (like Harleys with straight pipes) is, as mentioned, running lean which leads to hotter exhaust which can, and does sometimes, eventually burn exhaust vaslves...
