Tartan Terror Posted October 4, 2006 #1 Posted October 4, 2006 Here in the Northeast it gets pretty cold but not always snow. I want to be able to ride all season as long as the roads are clear. What im looking for is a good quality garment. Gloves and vest or jacket liner. I want to be able to connect the gloves to the vest or liner or use the gloves alone. Last but not least I want to be able to adjust the temp so I dont bake myself. Tell me what you use
JayJay Posted October 4, 2006 #2 Posted October 4, 2006 Here in the Canadian Prairies we wear heated vests in the spring and fall and we put a switch in one of the wires to enable us to turn it on and off. I fed the power wire up the front of the seat and installed the switch on the vest. It sits near the top of the seat allowing for easy access. JayJay
Tartan Terror Posted October 4, 2006 Author #3 Posted October 4, 2006 Here in the Canadian Prairies we wear heated vests in the spring and fall and we put a switch in one of the wires to enable us to turn it on and off. I fed the power wire up the front of the seat and installed the switch on the vest. It sits near the top of the seat allowing for easy access. JayJay Which ones do you use and do you like them?
breakingparts Posted October 4, 2006 #4 Posted October 4, 2006 Gerbing. Here is the link to the best dealer around. Life time warranty http://heatedclothing4you.com/
stardbog Posted October 4, 2006 #5 Posted October 4, 2006 My Vote is going to Widder Heated Clothing Very helpfull tread was month or so ago Check Out this one http://www.venturerider.org/forum/showthread.php?t=1244 http://www.widder.com/ http://www.gerbing.com/heat/urjacket.html#
Bvinson Posted October 5, 2006 #6 Posted October 5, 2006 Here is another option. Good stuff, made by folks in "Minnnnasootaaa". I think thats how OWL would say it. http://www.1stheat.com/accessorypage.htm
