The end weights on my 2006 RSTD are different from my 2009 RSV.
The RSTD have a alan head bolt that goes through them and the shoulder is unthreaded.
On my RSV, the weights are solid (no bolt) and are threaded on the shoulder to screw into the grips. So,, may be different.
You may be able to tell from looking at the plastic plug on the end.
The RSTD has a one about half dime size, the RSV is dime size.
Mike G in SC
Mike G in SC
My '99RSV has this style..... which sounds like what fits an RSTD??
I don't think so. My '99 has the same kind as you are picturing. I think he is saying that the RSTD weight have a allen head bolt that goes all the way through the weights and then into a threaded hole in the end of the bars. If I read it correctly.
Coulda swore that when I took the weights off my '99 I had to use a hex wrench to get them off, and those were the same type?? Guess not?? Halucinating again...:backinmyday:
No, you are correct. They do have a hole for a hex wrench under the chrome cap. It turns the entire weight to screw them off though. I think he is saying that the RSTD has a separate long bolt that goes all the way through the weights. The RSV is all one machined piece.
I think that this is the diagram for the RSTD bars and weights. You will see that item 4 is a long allen head bolt. The RSV does not have this bolt, they are a one piece machined piece.
http://www.partshark.com/fiche_section_detail.asp?section=75066&category=Motorcycles&make=YAMAHA&year=2005&fveh=1732
Here is the list for the RSV, it does not have the bolt but the end of the weights are actually threaded instead.
http://www.partshark.com/fiche_section_detail.asp?section=557621&category=motorcycles&make=YAMAHA&year=2008&fveh=12947
Whew!!! Thanks for digging that info out. Feel better now, and will cancel the psych appointment..... :whistling:
