Opinions on this...
I have :
- passing lights (relay to battery, on/off switch on fairing)
- Stebel Horn w/bracket and wiring harness with relay
- 5 to 4 wiring converter/isolator (Reese - requires power)
- trunk wing (doesn't require power but wiring is in there too)
Connecting the bike's positive power cable plus 3 others and it was getting pretty messy on the battery post. Couldn't find a small enough (and covered) "power bar" so I kind of made my own. Used 16 gauge wire with eyes/rings on both ends and slipped it and the other wires (with eyes/rings) onto a bolt and put a nut on it to hold it secure (you can see it sitting on top of the battery wrapped in electrical tape).
Each accessory using power is fused.
I figure the 16 gauge wire from the battery should be enough to carry the load from the three devices requiring power. This a good way to do it or bad? Comments?
I added a small fuse block under the seat so I only have one extra lead from the battery and run everything off it. I will get the part number and a pic when I get home if you would like.
I'm thinking that 16 gauge might be a little light,,, might better go with 12 gauge for the main lead. I would think as well that there should be a 1 to 4 connector available to do that job so that it can be taken apart more easily.
But it looks serviceable, at least for now.
That would be my solution too.
Feed the block with a 10g wire, with an in-line 30 Amp fuse. That way the combined accessories won't threaten the power feed.
These guys have everything you need. The Fuse Blocks start at around $5:
http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0423FE0B7E613501F554072+M50+ENG
I did the same thing. It's hard to find the right one. A marine store is the best place I found.
I went to NAPA and bought the 8 bank fuse block. I was going to mount the block on the area behind the battery and to make it fit, I cut the block into two pieces. The buzz bar is one piece and the other is the fuses. Works great and no bunch of wires on the battery terminals. I used 10 ga wire fused to the battery. BTW I left the battery minder lead on the battery since I have in the past jumped my battery through this and started other bikes using a clamp adapter. After MD last year, I installed a 12V accessory plug in my trunk. Great to use the charger for the phone, bluetooth, and gps. Whoops - not all at once!!! I'd need another adapter for that.
MIKE aka Uturn
:Venture:
