What would be the proper relay to wire the passing lamps?
I'm assuming that something like this could be purchased from the local auto parts store.
I used a 30 amp LIGHT (continuous duty) relay. This is heavier than you really need, but the price is the same as a 20 amp. I believe in going with heavy amp circuits when possible. My auto parts store had a plug to put on the relay to make the wiring a little easier.. :thumbsup:
Thanks Steve. I like to err on the side of caution as well.
What, exactly, was the plug you're referring to? I'm assuming it in the same section as the relay.
