bendtdj Posted April 12, 2011 Posted April 12, 2011 While attepmting to remove the headlight bulb tonight, the socket (where the bulb plugs into the wireing) broke. I am guessing this socket, fixture, plug, or whatchamacallit, is part of the wiring harness. Is there anything a person could use to replace this? Other than a new harness? I think that I will get this fixed and then hire someone to do things for me. Fix one thing and another breaks. :confused::confused24: Might give up completely, go into debt, and buy a Can-Am Spder. At least then it would be warranty work. Thanks, Dave
dingy Posted April 12, 2011 Posted April 12, 2011 While attepmting to remove the headlight bulb tonight, the socket (where the bulb plugs into the wireing) broke. I am guessing this socket, fixture, plug, or whatchamacallit, is part of the wiring harness. Is there anything a person could use to replace this? Other than a new harness? I think that I will get this fixed and then hire someone to do things for me. Fix one thing and another breaks. :confused::confused24: Might give up completely, go into debt, and buy a Can-Am Spder. At least then it would be warranty work. Thanks, Dave If you can't find a socket at an auto parts store, I should have one lying around you can have. You'll need to solder it into harness of course. Finding it is the question. Gary
painterman67 Posted April 12, 2011 Posted April 12, 2011 they do sale the soket at local auto parts stores/ I had to replace the ones on my wifes shadow. It was a simple switch. Just figure out which wire goes where and splice in with butt joints and then heat shrink for protection. Not sur eof parts number but the local stealor here has a replacement socket that is made out of ceramics that they sale along with a brighter bulb. Good luck David
MiCarl Posted April 12, 2011 Posted April 12, 2011 they do sale the soket at local auto parts stores/ I had to replace the ones on my wifes shadow. It was a simple switch. Just figure out which wire goes where and splice in with butt joints and then heat shrink for protection. Not sur eof parts number but the local stealor here has a replacement socket that is made out of ceramics that they sale along with a brighter bulb. Good luck David Yeah, just cut it off the harness (leave about an inch of wire on the plug) and take it to the auto parts store. They'll have one. Use the old plug as your guide to which wire connects where (that's why you leave an inch of wire on it)
bendtdj Posted April 12, 2011 Author Posted April 12, 2011 Thanks, guys. It is not how much you know, it is all in knowing who to ask!! That is why this is such a great bunch of people here. :cool10: Take care, Dave
