Rody 1949 Posted April 8, 2011 #1 Posted April 8, 2011 I would like to install running and brake LED tail lights (I understand they don't draw much power from the electric system/battery, right?) and yet they look very cool to me. I'm pretty sure some of you have done it to your rides. Could you please tell me where do I get those, I know I can google it but, I prefer just follow what you have done. Thanks Rudy:)
Thom Posted April 8, 2011 #2 Posted April 8, 2011 Yep I did it , got them from superbrightled make sure you get the red ones , before i rewired the cms i used 1 1157 and 1 1157 red led so the darn flashing warning would not go off , somebody here posted how to bypass the cms but i forget who . do a search and you will find it . Thom
Flyinfool Posted April 8, 2011 #3 Posted April 8, 2011 Here is where I started http://www.venturerider.org/forum/showthread.php?t=21986 Not the easiest but looks very good.
dingy Posted April 8, 2011 #4 Posted April 8, 2011 Thom said: Yep I did it , got them from superbrightled make sure you get the red ones , before i rewired the cms i used 1 1157 and 1 1157 red led so the darn flashing warning would not go off , somebody here posted how to bypass the cms but i forget who . do a search and you will find it . Thom First set of pictures shown jumpers on a CMU with a gear indicator in it. [ATTACH]55449[/ATTACH] [ATTACH]55450[/ATTACH] Next picture is showing high & low beam warning jumpered out. [ATTACH]55451[/ATTACH] Last is a picture salty dog posted of the standard CMU layout. Gary
Rody 1949 Posted April 8, 2011 Author #5 Posted April 8, 2011 Ok, I'm going to read it carefully before I do something wrong, I'm sure I'll ask a couple more questions. Thank you so much. Rudy
Flyinfool Posted March 1, 2012 #6 Posted March 1, 2012 OK so I am about ready to spring to have ALL led lights on my 88 standard except for the headlight. I want to do the front and rear turn signals, running lights, brake, and all dash lights. I know that Superbrightleds carries them, as do others, but they have a boatload of different styles of 1157 light. and 194 lights. Can some one that has done this and is happy with their result let us/me know specifically which LED lights worked for everything. I can deal with the flasher and CMU issues. I just need the bulb info.
mbrood Posted March 2, 2012 #7 Posted March 2, 2012 Here's what one of the guys did... LEDs for wedge mount From superbrightleds.com... Amber bulbs that go in the rotorcover are WLED-A4 and are $1.59 each (4 LED narrow beam, amber). The red 9mm bayonet type bulbs are BA9s-R and are $.98 each. The bulbs I used in my upper light bar that are the blade type that I needed the light to come out sideways were WLED-R that are red, single LED, wide-inverted cone tip. These were $.87 each. Brighter Brakes and turn signals The stock bulb for the RSV is #1157. specs are 32/3 candlepower. Bulb # 2357 has the same base, plugs right in. Specs 40/3 candlepower. Running light will be the same brightness, brake light will be 25% brighter. If anyone is worried about the extra heat melting the lens...I've been using these bulbs in my '83, brake and turn signals, for about 8 years. I use the 2357LL (long life). front bumper and trunk turn signal in amber Quantity: 6 Product: WLED-5 Wide Angle LED bulb $ 2.79 (each) Options: Amber Accessory running lights/wide angle/side view Quantity: 18 Product: WLED-R Red LED bulb $ 0.89 (each) Options: Wide - Inverted Cone Tip Front disc brake rotor cover for 84 and 86... in amber Quantity: 8 Product: WLED-A4 Amber LED bulb $ 1.59 (each) Trunk and reflector red lights Quantity: 12 Product: WLED-5 Wide Angle LED bulb $ 2.79 (each) Options: Red http://www.superbrightleds.com ---------- PRODUCT INFORMATION ---------- Qty | Product / Options | Price/ea | ================================================== ========== 5 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-W4-90: Cool White Wide 1 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 1.59 | WLED-R4-32: Red Narrow 2 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-G4-32: Green Narrow 1 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 2.59 | WLED-B4-90: Blue Wide 3 | WLED-x4-x: 4 LED T10 Wedge Base Bulb | $ 1.59 | WLED-A4-32: Amber Narrow 2 | 1156-x30: 30-LED BA15S bulb| $ 8.99 | 1156-A19-WV: 1156 Amber 100 Degree 2 | 1157-x3X1W: 3 x 1.3 Watt High Power LED BAY15D Bulb| $ 16.95 | 1157-A3X1W: Amber 2 | 1157-R19W6: Motorcycle Tail 19-LED 1157 Bulb| $ 12.99 | 2 | RL-650: Tail Light Load Resistor kit | $ 4.95 |
