tbbrider Posted April 6, 2011 #1 Posted April 6, 2011 (edited) Need some advice from my fellow trikers. I am recovering from shoulder surgery.My trike has the front wheel raked.Will 1 1/2 inch risers help it steer any easier? I know if anyone knows the answer ,you riders will.PLease chime in so I can order a set.I don't write a lot of posts,but I past my time every night reading the posts. Thank guys. Edited April 7, 2011 by tbbrider
Chinto Posted April 6, 2011 #2 Posted April 6, 2011 Risers will help reduce your arm shoulder reach and lower your arm hold position but I don't believe it will make your trike turn any easier. The reason a bike will turn easy is the lean initiated by counter steering which you don't have on your trike. If you have short arms like I do and want to lower the shoulder arm hold then risers are the way to go.
