I noticed coolant leaking from the left rear cylinder...
http://i868.photobucket.com/albums/ab243/BriRit/2011-03-28_16-40-52_203.jpg
I removed the side cover from the cylinder and found this brass looking plug leaking coolant. What is it, and how do I fix it?
http://i868.photobucket.com/albums/ab243/BriRit/2011-03-28_16-45-54_601.jpg
The brass threads are only there to assist in removing plug. A spark plug end will thread in there and it will pull straight out. This goes to the cavity surrounding the cylinder sleeve.
P/N 90338-11152-00
About $6
Gary
