VentureT Posted March 28, 2011 Share #1 Posted March 28, 2011 Hello all, I has a slight coolant leak under the cylinder "fins" that developed over the winter while in storage on my '03 RSV. From talking to people and reading posts by the fine folks here, I ordered in new plugs and changed all 4. Taking out the old ones, I lost some coolant as expected. The new plugs fit fine and I have no leaks now. The question I have is the new plugs have a female thread in the center of them for a bolt or screw. The old ones were just rubber with no threads. Is there supposed to be a bolt or screw that goes in the threaded portion of these new plugs? Thanks. Link to comment Share on other sites More sharing options...
dingy Posted March 28, 2011 Share #2 Posted March 28, 2011 On the first gens, that screw hole was to be used to remove the plugs. I think the service manual said to screw a spark plug end in there and use it to remove plug. I just got new ones for my 88 motor and they had the screw thread in them. Gary Link to comment Share on other sites More sharing options...
twigg Posted March 28, 2011 Share #3 Posted March 28, 2011 On the first gens, that screw hole was to be used to remove the plugs. I think the service manual said to screw a spark plug end in there and use it to remove plug. I just got new ones for my 88 motor and they had the screw thread in them. Gary Where did you get them, how many do you need? Mine are old and I would replace them as a matter of course. Thanks Link to comment Share on other sites More sharing options...
Rocket Posted March 28, 2011 Share #4 Posted March 28, 2011 Where did you get them, how many do you need? Mine are old and I would replace them as a matter of course. Thanks Yammi dealer (need to order in) PLUG,SPEC'L SHAPE 90338-11152-00 Qty 4 & retails at $5.74 each. Link to comment Share on other sites More sharing options...
