Any way to tell if you have good spark or if your spark is weak in your ignition system:sick:
A Sparktester inline with the plugs will help.
They start at around $5
[ame=http://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6]Amazon.com: Lisle 20610 Inline Spark Tester: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31ZD5T1ARRL.@@AMEPARAM@@31ZD5T1ARRL[/ame]
:sign yeah that:
That will do nicely. I have an older model type with an open body around the electrodes. I always know I have good solid spark when I have to comb my hair when I'm done testing.
Should be a danged warning on the thing, "Do not use while sweating" Might as well hold the plug wire with my teeth. :eek:
