Al Bates Posted March 27, 2011 #1 Posted March 27, 2011 Patriot Guard Rider patchs? What is the differents? Check out pics below. Proud member of the Patriot Guard Riders http://www.patriotguard.org Thanks Al Bates
ragtop69gs Posted March 29, 2011 #2 Posted March 29, 2011 You just can't win Al I guess we did kinda hijack Al's thread. As was said earlier, the oval patch is a special fundraiser patch. The other patch you showed is usually used as a back patch on a vest or jacket, it is also sold as a magnetic sign to use on your cage during inclement weather missions. If you go on a few missions you'll see many different ways people use all the different PGR gear.
Freebird Posted March 30, 2011 #3 Posted March 30, 2011 A question was asked and I've left the simplest answer for all to see. I've removed all the other posts and will now close this thread. I had no problem with the explanations but it had sunk to the level of members going after each other.
