Leeway Posted October 2, 2006 #1 Posted October 2, 2006 I'm looking at replacing my brake pads all the way around. What brand & where is the best place to purchase them? I also want to look into the stainless steel reinforced hoses. anyone with thoughts or suggestion in this area? wayne
sarges46 Posted October 2, 2006 #2 Posted October 2, 2006 Try Rick at www.buckeyeperformance.com , He has all the parts you need and carries the steel cables made for the 1st gens. Good to deal with too.
Squidley Posted October 2, 2006 #3 Posted October 2, 2006 Wayne, Rick at Buckeye is a good source for the braided lines and EBC HH pads are a real good set to use, have 'em on the '99 and I'm very pleased with them.
Venturous Randy Posted October 3, 2006 #4 Posted October 3, 2006 Like Brad said, EBC HH brake pads. The ones I got were that plus they said "Superbike". It has made a huge difference in stopping my 83. It was part of my upgrade in pulling the camper. randya
Leeway Posted October 3, 2006 Author #5 Posted October 3, 2006 Thanks Guys, I'll try the "EBC HH" I'll check with a local shop to see if he's got what I need in stock. If they haven't I'll shop the net to compare with Rick.:)wayne
Guest Flash Posted October 4, 2006 #6 Posted October 4, 2006 The kevlar type stop you quicker but wear quicker. I have just replaced mine with sintered type pads. Stops really well now. I had the kevlar type in before, once they wear down there is little stopping power.
Al Bates Posted October 4, 2006 #7 Posted October 4, 2006 EBC HH pads are the only break pads I'll use, I will try others but alway go back to EBC. Don't have to be HH I believe HH is higher heat (Heat I think)
Starrider04 Posted October 4, 2006 #8 Posted October 4, 2006 Same here use EBC, good brakes at a good price.
Tartan Terror Posted October 4, 2006 #9 Posted October 4, 2006 On the steel braided hoses I use nothing but. The thing I like about them is that the lever and pedal are much firmer. On rubber hoses when you squeeze they expand a little and kind of loose a little of the force. Because of the Steel braid the Steelbraid hoses dont stretch the same and it is more a positive feel. I use Dot 5 fluid in mine as it is silicone based and wont absorb as much water as well as not hurt the paint if you spill it. i have this done to both my bikes thought opinions will differ. I also did the clutch like too.
RustyNails Posted October 5, 2006 #10 Posted October 5, 2006 Tartan Terror said: On the steel braided hoses I use nothing but. The thing I like about them is that the lever and pedal are much firmer. On rubber hoses when you squeeze they expand a little and kind of loose a little of the force. Because of the Steel braid the Steelbraid hoses dont stretch the same and it is more a positive feel. I use Dot 5 fluid in mine as it is silicone based and wont absorb as much water as well as not hurt the paint if you spill it. i have this done to both my bikes thought opinions will differ. I also did the clutch like too. Did you have to change out your seals when you went to DOT 5? I am going to change to S/S cables when I change my pads and would like to change from DOT 3.
