kyle Posted March 17, 2011 #1 Posted March 17, 2011 anybody know what the little hose under water pump is for and should it be hooked to anything?? it heads toward the oil filter and just dangles there. another thing is just put on a newn front tire "avon" and now i have the slightest "ticking, zzzzzzz, faint card in the spokes sound, slows down when i do and doesnt change under braking or weaving back and forth. I check bearings when wheell was off and seemed ok and torqued to specs, what the @#$% gives.
Guest scarylarry Posted March 17, 2011 #2 Posted March 17, 2011 Does it make the sound when off the ground?
kyle Posted March 17, 2011 Author #3 Posted March 17, 2011 no havent noticed. only at about 15 mph or faster. could it be the new sharper edges on the tire grooves or all the rubber whiskers.
Guest scarylarry Posted March 17, 2011 #4 Posted March 17, 2011 Mine may a clicking noise when off the ground took the brake pads off file the edge off a tad bit then it stop.. Never heard it when I rode only when in the air and wheel was spun freely
