What did you use to drive in the bushing and seal? I can't find a PVC pipe the proper size and I'd hate to sink $40+ into a tool that I'm only going to use once.
I don't know the specs on the 2nd gen forks but this is what I use for a seal tool on forks.
The PVC is 1 1/2 ID with a coupler and a reducer. I have couple of reducers for different tube sizes, each shaped by grinder to fit as needed.
The reducers have an octogon end (that I grind down to fit the outter tube) so it is thicker than the PVC pipe itself and fits the seal body well. The upper wiper lip fits nicely inside the ID of the reducer to protect it while being pressed into place.
Hey, it's cheap, about $7.00 for everything, reusable and works on several sizes.
As far as bushings on yours.....I have no idea. 1st gens just snap into a recess.
Mike
Mike
Yup, Yup. That's the inexpensive ticket.:)
I may have the right size driver, I'll measure the driver I have and the upper on my VR, I presume the RSTD is same size upper legs?
I made the tool for a Vulcan, they are 41mm, my VR appears to be 40mm. Can yo measure the outside diameter of your new seal? If my driver is small enough to clear the OD it'll work
My tool appears to be in my truck, it's not here at home. If it won't work I'll whip one out for you tomorrow. 2 chunks of aluminum , 25 minutes on the lathe and it'll be almost too shiney to use.
When will you be in Lex to pick it up?
So to work, it needs to be 43.5 x 53.5, and about 250 long
But it was made to the sizes given. What size does the inner leg measure?
Looks like the 42mm given is not the size of the leg? Can you measure it?
I have to attend a meeting in Cincinnati tomorrow at 11:30am, when I leave there I'll call you at the number you called me from today
Sounds good.
