dingy Posted March 15, 2011 #1 Posted March 15, 2011 Anyone have a 1300, 1200 may also work, block that is split in half, I need some help on the location of the two oil nozzles in the care halves. When I sent block to machine shop, top & bottom, because they cleaned them, I took everything out. Including the two small oil nozzles & tossed them in a baggie. Well when cleaning stuff I realized they were different and I can't tell which one goes in which hole. 1st picture is attached of two nozzles. Left one is brass color with phillips slot, other is silver with straight slot. 2nd picture is of case top, and 3rd is of case bottom, locations for these. The 88 parts fiche indicates they both go into the bottom case. The service manual doesn't mention them that I can find. And, the VMax is different. The motor DVD mentions them but doesn't show them. The 83 1200 fiche shows them going into the case where I am 99.9% sure they go, but doesn't show the difference. Gary
Reddog170 Posted March 16, 2011 #2 Posted March 16, 2011 I can find it in the service manual, the problem is it LOOKS like one way but the part numbers are obslete now so I am having trouble locating them. The part # that goes in the upper half is 26H-15138-00-00 and the part number for the lower halk is 4g0-15138-00-00 Hope this helps some. Shaun
dingy Posted March 16, 2011 Author #3 Posted March 16, 2011 Thanks Shaun, doesn't lock it down for me though. Part is to small to have any numbers on it. That may end up being the answer though, I had to order new main & rod bearings because I screwed a crank up & I ordered one of the nozzles at the same time It was about $5 more, but that's the price I pay for not being more observant.. When it gets here I will know where it goes and the other one goes to Gary
talonsx2 Posted March 16, 2011 #4 Posted March 16, 2011 The silver straight slot goes underneath the balancer bearing on my 1200.. Hope that helps. mike
