Changing 2nd Gen Speakers
From what the guys posted last week about the Polk's
I ordered two of them and I think they are great sounding!
Two Summers ago I changed the stock speakers to
Pioneer TS-G10400's the speakers are OK but just not
there yet.
I then added bass blockers and it helped. now with the
blockers added to the new Polk's (front only) Moocho better.
The Polk's can handle a little more power (amp in trunk)
so combined with the bass blockers it really sounds great
even with-out the fairing on the bike. That is the problem
with the fronts.. not like the rear on the RSV. (in a pod un-cased)
sound much better. So I left the Pioneers in the rear for now.
Here are some pics of all 3 speakers
OEM SPEAKERS (Junk)
Pioneers Much Better
Polk's Even Better 107DB400Polk Audio db 400 4" 2-way Speakers
1049.9949.99
Here is all 3 of them top view
And side view
Now with that being said, here is how you remove
and put them in a 2nd Gen.....
#1 Remove Fairing. (there is no going in from the front)
#2 Remove the gold bracket
and the black box (blinker box>?)
#3 Remove the Philip's screw for each speaker
#4 Start removing the four screws holding the speakers
in place.. use a 8mm wrench when you can and a 5/16
deep socket for the hard to get to ones.
#5 Now with all the screws removed you start to pry
the front bikes grill along with the speaker a part.
If adding Polk's you will need to enlarge the (2) inner
holes a little bit.. (2 holes that will face the middle of the bike)
#6 when adding the new speakers the (inside holes will be placed in-between the plastic as show)
NOTE: I did place small pieces of cardboard in-between the metal
bracket and the magnet so it Will help NOT to demagnetize the speakers.
#8 DONE
(replaced everything in reverse order)
Now CRANK IT UP!
Happy Riding!
Jeff
Notes:
2-way 4" car speakers
polymer/mica composite woofer with butyl rubber surround
liquid-cooled, silk/polymer composite 3/4" dome tweeter
certified for marine use
2-way crossover network
recommended power range: 4-35 watts RMS
peak power handling: 105 watts
frequency response: 85-22,000 Hz
sensitivity: 91 dB
top-mount depth: 1-13/16"
Edited by Freebird
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Good article -- especially with all the pictures. I've added it to my favorites, as upgrading my speakers might make it to my "Winter Mods" list.
Do you have the model/part no. for the Polk speakers? I might as well learn from your experience and skip the step of using the Pioneers. Thanks, Cougar!
Jeff,
I noticed the POLK speakers you installed aren't just limited to use in your car — they've passed tough environmental testing that certifies them for marine use.
It looks like the DB400 have been replaced by DB401, most lickly the same speakers just a number change. With my hearing :backinmyday: I think an old soup can and some string will work just fine.:rotf::rotf::rotf:
Great write-up. I will add it to the tech library soon. One note. I doubt that these would work in the rear pods. Looks like the magnet is a big deeper. I originally tried some Infinity speakers on my '99 and they would not work in the rear either. The pods would not go back together due to the size of the magnet. That being said, I think that you get very little from the rear speakers. The fronts are where most of your sound comes from. I will likely give these a try also. I too am running the Pioneers at this time but am not completely happy with them.
Crutchfield still has both listed. They may just be selling out the existing stock of the 400 though. The difference appears to be the power rating. 105 peak for the 400s and 135 peak for the 401s. RMS tops at at 35 for the 400s and 45 for the 401s. I actually think that the 400 model will be better for our bikes AND they are $30.00 cheaper than the 401s.
Now keep in mind... I am using bass blockers. to be able
to crank up my Polk's even higher. (used with amp)
so the rumble doesn't-
Force you to turn them down.. I do however like the highs
coming out of the Polk's better.
Don. I used the F/S control. or whatever you call it,
and adjust my rears to match the front of the bike.
but your right a lot does come out of the front.
(but is adjustable)
Jeff
I use the 401's for my Venture. Front only right now. I installed them last spring.
They are the best speakers I have tried. Very good sound and yes they are marine grade.
I have been trying to figure how to make the front
speakers sound like the rear. with some kind of backing
for the sound to be even better. These caught my
eye while surfing around in crutchfields..
I hope they fit! :confused24: there might be just
enough room in there!
http://www.crutchfield.com/S-1b0A1wum8mx/App/Product/Item/Main.aspx?i=237XT42
I think this is the ticket for the front.
I ordered the slim type. I will let ya know how
they work!
Jeff
Talked with Crutchfield today and they say that the 400's
will be going out of stock.. HURRY there is only 464 Speakers left! *lol*
401's will take there place. I think I will try the rear next. but gunna
look in the rear pod for room first. like Don says , waiting till me back
covers show up first. then I will do a write-up on how to remove/replace
the rear 2nd Gen Speakers as well. For the price and if they do no work
I will have spares I Guess :) gunna put the Speaker Baffles in the rear
as well... Also they told me to make sure I cut a dime size hole in the bottom of the baffle to make the suction not be so bad. I will add these
baffles to the write ups. gatta do somthing in these Iowa Winters!
Stay Tuned! :cool10:
Jeff
Bill, ya know you are allowed to try them out with-out
riding the bike ! :whistling:
I Just ordered two more for the rear. and I now have all
4 Baffles to place over the speakers I really think the baffles
will be the topper for the rest of the sound that I need..
Jeff
PS (great you did not have to enlarge the holes)
  • 5 weeks later...
Glad you like them Bill...
Yes , that is why I Installed the AMP in my trunk
to get the Volume I needed , I even did that before
the Polk's though.. It Also helps Lots with my new
Zumo GPS to hear what it is saying and also help
the music come from that even louder.
Anyway , I am glad you had success with them.
can not remember if you changed out the rears yet or not?
(did you add bass-blockers?)
I still have not installed my second set yet into the rears.
Some say there might not be enough room. I will get them
to fit some how :) with the baffles. I also still have not
installed my baffles to all four speaker as well. *sigh* to
damn COLD.... Buurrrrrr :snow:
Jeff
After Cougar'swrite up last night I started looking for some 400's. I did some checking and the 400 are 1 13/16 thick and the 401's are 1 15/16 thick so I guess we should stick with the 400's if the 401's are 1/8 inch thicker.
But that measurement MAY be withe the cover installed, which we dont use....
for the price diffence, I would buy the db400's
The Back Cover Baffle is about an 1/8 th inch thick..
But when I installed it back into place it compressed part
of the baffle just a bit. seems like there might be a 1/16 inch
left? not sure. hard to tell. I think somebody if they bought 2
of the 401's.. and before the placed them into the front of
the bike maybe try a test fit on one of the rears.. :whistling:
Jeff
  • 3 weeks later...
  • 2 weeks later...
