w.steve wells Posted March 12, 2011 #1 Posted March 12, 2011 i added the saddlebag side rails trim and had to remove the side reflector from the crash bar is there a replacement for the smaller size bars or someother type that can be added. thanks for replies
eusa1 Posted March 12, 2011 #2 Posted March 12, 2011 the added rails would come with a black split hose to put inside your reflectors to take up the space and allow you to install them horizontaly on the smaller rails. mike
w.steve wells Posted March 12, 2011 Author #3 Posted March 12, 2011 well i guess the factory forgot to package one with my set of rails so i'm off to the hardware to buy a short hose to fit so thanks for the tip, spring's a comming so ride safe everyone steve
Nemo Posted March 13, 2011 #4 Posted March 13, 2011 I have a question. Where can I buy a set of those reflectors?
eusa1 Posted March 13, 2011 #5 Posted March 13, 2011 I have a question. Where can I buy a set of those reflectors? yamaha still sells them, same from 1999 to 2011
Kirby Posted March 13, 2011 #6 Posted March 13, 2011 Go to Lowe's or Home Depot and get 4 rubber grommets to use to adapt the reflector to the smaller rail. If I were at home I could send you a pic. Maybe later tonight.
Kregerdoodle Posted March 13, 2011 #7 Posted March 13, 2011 Mine didn`t come with them either... well i guess the factory forgot to package one with my set of rails so i'm off to the hardware to buy a short hose to fit so thanks for the tip, spring's a comming so ride safe everyone steve
Rick Haywood Posted March 13, 2011 #8 Posted March 13, 2011 I just put a set on mine and they didn't come with it either but then again I didn't have the reflectors on the crash bars anyway so worked out great.
Kirby Posted March 13, 2011 #9 Posted March 13, 2011 This is what I found to mount my reflectors with. They need to be 3/4 inch inside diameter by 1 inch outside diameter measured at the bottom of the groove.
