Rick Haywood Posted March 3, 2011 Share #1 Posted March 3, 2011 I was changing the plugs and putting in new air filters and noticed something I had bever seen and was wondering what it might be. On the right side of the bike right behind the rear carb there is a small tube that runs from right side torwards the left side. It is moounted on the back side of the carb and has a little knob on it that you can rotate. Does anyone know what it is for? Link to comment Share on other sites More sharing options...
flb_78 Posted March 3, 2011 Share #2 Posted March 3, 2011 http://venturerider.org/forum/showthread.php?t=57099&highlight=tube Carb overflow Link to comment Share on other sites More sharing options...
Rick Haywood Posted March 3, 2011 Author Share #3 Posted March 3, 2011 http://venturerider.org/forum/showthread.php?t=57099&highlight=tube Carb overflow Nope, this one isn't an over flow it is very small and has a little knob on the end that you can rotate left or right Link to comment Share on other sites More sharing options...
Scooter Bob Posted March 3, 2011 Share #4 Posted March 3, 2011 It is moounted on the back side of the carb and has a little knob on it that you can rotate. Does anyone know what it is for? Is it hanging up close to the bottom of the tank, on the right side, above the rear head, black tube, black knob, about 1/2-3/4" diameter? If so, it is the idle speed adjustment. You can tweak it as needed for temp, weather, or... to set the idle way up so you can start the bike moving with just the left hand on the clutch while holding a 4 foot long 2x2 in your throttle hand to bust potatoes that are on the top of a bunch of sticks along the track. (believe me, it can work) Gotta love the bike games at the ABATE of WI Summer Hummer. Later, Scooter Bob Link to comment Share on other sites More sharing options...
Aussie Annie Posted March 3, 2011 Share #5 Posted March 3, 2011 The rotating knob tubular whatsit for an XVZ1300 Venture...small size Link to comment Share on other sites More sharing options...
eusa1 Posted March 3, 2011 Share #6 Posted March 3, 2011 idle speed adjuster rick, it also has a phillips screw slot in the center of that knob. it's a cable in the center of that black tube. Link to comment Share on other sites More sharing options...
Rick Haywood Posted March 3, 2011 Author Share #7 Posted March 3, 2011 (edited) Thanks Guys, I kinda thought that was what it was for. Edited March 3, 2011 by Rick Haywood Link to comment Share on other sites More sharing options...
MikeWa Posted March 3, 2011 Share #8 Posted March 3, 2011 If you keep your idle speed down to about 950 it won't slam when going onto first gear either. Mike Link to comment Share on other sites More sharing options...
Rick Haywood Posted March 3, 2011 Author Share #9 Posted March 3, 2011 If you keep your idle speed down to about 950 it won't slam when going onto first gear either. Mike Must be set about right then cause mine doesn't slam into first. Link to comment Share on other sites More sharing options...
