CaptainJoe Posted March 3, 2011 #26 Posted March 3, 2011 nada says: 2737 avg trade-in 3262 clean trade-in 4937 retail you could start at $3500 but i doubt you get it for that. If it's in very good shape I'd offer "up to" $4,000.
Skid Posted March 3, 2011 #27 Posted March 3, 2011 Might be a short time fix for a couple more years, but did you ever consider doing body work? Might be cheaper than replacing it if the drive train is still good....
Yammer Dan Posted March 3, 2011 Author #28 Posted March 3, 2011 Might be a short time fix for a couple more years, but did you ever consider doing body work? Might be cheaper than replacing it if the drive train is still good.... I thought about that but if you took a look under that thing it is really bad where you can't see.
BradT Posted March 3, 2011 #29 Posted March 3, 2011 http://www.autotrader.com/dealers/inview/detail.jsp?ct=u&car_id=291773260&dealer_id=57764155&car_year=2003&dealership_view_name=kevinsautosaleswva&address=25113&sort_type=make_modelASC&cardist=5737 Cost more but 3 yrs newer and top of the line Buick. This one is probally a 3800. I always thought they only put the 3.8 in the higher end models. dam the prices are high down there. Bought 03 impala two years ago with 60,000 miles put on 55,000 miles on the 3.4 and paid less than 5,000 CDN. Starting to rust a little but that is normal here with the amount of salt they use. Bikes are cheaper cars are not. BRad
Pam Posted March 3, 2011 #30 Posted March 3, 2011 If it was me I would be going for the buick, My neighbour is on his second one, and he is pretty picky when it comes to vehicles. I don't know what he has for power under the hood though. $6000.00 seems pretty steep to me. I am on my second 3.4 with no intake issues (so far, and touch wood when I say that) frank
Jayceesfolly Posted March 3, 2011 #31 Posted March 3, 2011 I have had four Buicks in the last 10 years and currently own two (Regal and LeSabre). Both have the 3800 engine and I wouldn't drive anything else. (Well, maybe a Cadillac that I have my eye on!). The Regal had the intake gasket replaced when I bought it (by the dealer) and that is the only thing that has been done with either car. This is a common problem with the 3800 engine and should be investigated by you before you purchase the car. Other than that gasket, never had a mechanical problem with either car other than regular maintenance items ie: oil change, tires, etc. The Regal is a '96 and is beginning to show rust this winter due to salt on the roads, but the body has held up well until this winter. I am going to sell the Regal and probably buy that Caddy this year. I have never checked the mileage on the Regal as we only drive it around town and don't care what it gets, but we get about 32 MPG in the LeSabre on the highway and 22 MPG around town. I usually drive the speed limit and am not a leadfoot, so the mileage is probably typical.
Black Owl Posted March 3, 2011 #32 Posted March 3, 2011 If you decide on the Buick, make sure that the recalls have been completed. This make/model year had at least 5 recalls issued. Two were for potential fires and one was for a steering failure potential. Hate to see you end up sitting in a ditch somewhere in a smoking ashtray.
naturbar Posted March 3, 2011 #33 Posted March 3, 2011 I thought about that but if you took a look under that thing it is really bad where you can't see. now that made me laugh..... how can you look where you can't see?? for me it's usually i can't see where i look !!
Yammer Dan Posted March 4, 2011 Author #34 Posted March 4, 2011 (edited) Can't see the rust til you get down under the thing. I could patch holes but this is pretty bad. Lower rocker panels under plastic trim gone and door frame eating away. Much longer and floor pans and roof will be all holding it togather. You could not see this when I bought the thing. I first noticed whem I started to jack the thing up and jack just kept going up without raising car. Salesman probally still laughing. Edited March 4, 2011 by Yammer Dan
Wolf Posted March 4, 2011 #35 Posted March 4, 2011 Recalls for the Buick. The 3.1 liter is prone to cylinder head failure. 75% of the time you will have to replace the head as the gasket is not the cause. Number Date Title 04052 09/01/2004 Recall - Headlamp Non-Compliance NHTSA04V375000 08/06/2004 Recall 04V375000: Low Beam Headlamp Bulp Replacement NHTSA99V356000 12/17/1999 Recall 99V356000: Headlamp Adjuster Calibration Defect NHTSA99V170000 08/25/1999 Recall 99V170000: ABS Motor Electrical Short for the intrepid. BTW if it is the 2.7 engine, they have a catastrophic engine failure due to a under sized oil pick up in the engine oil pan. There is an update for it. Transmission, ECM, and TCM are prone to failure which results in transmission failure. Number Date Title C45 06/01/2004 Recall - A/T Shifter Ignition/Park Interlock Defect NHTSA04V021000 01/01/2004 Recall 04V021000: Shift Interlock Failure C04 04/01/2003 Recall - Driver's Seat Recliner Bolts NHTSA03V035000 02/01/2002 Recall 03V035000: Seat Back Recliner Bolt Breakage 978 08/01/2001 Recall - Seat Belt Retractor Replacement NHTSA01V119000 04/04/2001 Recall 01V119000: Seat Belt Retractor NHTSA00V034000 02/03/2000 Recall 00V034000: Seat Belt Defect 866 02/03/2000 Recall - Shoulder Belt Height Adjuster Bolt
Wolf Posted March 4, 2011 #36 Posted March 4, 2011 I'd buy the Saab,,, but stay away from the GM 2.5 v6. Buy now, Saab later.
saddlebum Posted March 4, 2011 #37 Posted March 4, 2011 (edited) The buick all the way. More reliable far better ride and much quieter inside. Plus chrysler has a history of transmission and torque convertor issue's. The buick 3.8lL is almost as bullit proof as the venture engine. I put 480,000 km (about 300,000 miles) on mine and never touched it. With regards to the intake manifold it is rare and it is still easier and less costly to fix than a transmission if it did leak. Edited March 4, 2011 by saddlebum
Yammer Dan Posted March 4, 2011 Author #38 Posted March 4, 2011 I'm leaning toward the 03 LeSabre. http://www.autotrader.com/dealers/inview/detail.jsp?ct=u&car_id=291773260&dealer_id=57764155&car_year=2003&dealership_view_name=kevinsautosaleswva&address=25113&sort_type=make_modelASC&cardist=5737 With that kind of miles and the 3800 it should last me for a while.
eagleeye Posted March 4, 2011 #39 Posted March 4, 2011 Dan, Don't you ever look at your local craigslist? Lots of deals to be had there. Buyer beware of course. Steve
Yammer Dan Posted March 5, 2011 Author #40 Posted March 5, 2011 No I don't. Really don't even know how to get there.
Wolf Posted March 5, 2011 #42 Posted March 5, 2011 If you find something you are really interested in, let me know and I will send you all of the TSB's and recalls from Alldata.
