Guest Ken8143 Posted February 27, 2011 Posted February 27, 2011 My 1st gen was marking its spot in the garage. Did a little checking and the little coolant bypass valve was dribbling like an old man with severe prostrate issues. So I get on VentureRider to find out more. About the bypass valve, not the prostrate. Now is this a site or not. I discover it is a common issue, not serious, and no surprise, Sky Doc has an inexpensive fix for it. With good directions that even I might be able to fix. :shock3:Which is a disadvantage because I won't wind up in the Little Shop by the Creek at Sky Doc's place, with Jean wondering how two grown men can have so much fun. All of that without having to send out an SOS for a question already asked, answered, and a cheap fix available.
skydoc_17 Posted February 27, 2011 Posted February 27, 2011 Hey Ken, Thanks for the kind words about the Radiator Drain Upgrade Kit. For the record, I try to limit my "Practice" to all things motorcycle! You are on your own, as far as that prostrate goes my friend! Seriously though, That Radiator Drain is a pesky little bugger and you will be glad you dealt with it before the warm weather comes. Thanks again for the Props, Earl
Beau-Kat Posted February 27, 2011 Posted February 27, 2011 It's prostate. Unles the pain gets too bad and then you will lay out prostrate on the floor.
